Driver Omron Fins
Olá, estou utilizando o driver fins para comunicação com um clp nx1p2, porém não está funcionando. Já segui o tutorial indicado no tópico Comunicação E3 com NX1P2 OMRON utilizando Driver SYSMAC, porém não funcionou.
o log apresentado é o seguinte:
11/03/2024 16:00:45.764 (6560) IOKIT INITIALIZED!
11/03/2024 16:00:45.764 (6560) IOKIT Request handler enabled
11/03/2024 16:00:45.764 (6560) IOKIT CONNECTING…
11/03/2024 16:00:45.765 (6560) SOCKET connecting socket to ‘10.10.90.123’ on port 9600…
11/03/2024 16:00:45.765 (3B64) TAG Tag(0.111.100.0).Validate = SUCCESS (type=10;flags=9)
11/03/2024 16:00:45.771 (6560) SOCKET socket connected to ‘10.10.90.123’ on port 9600 (local port 54810)!
11/03/2024 16:00:45.771 (6560) IOKIT CONNECTED!
11/03/2024 16:00:45.778 (6560) IO TX: 80 00 02 01 7B 00 01 15 00 00 01 01 82 00 64 00 00 01
11/03/2024 16:00:45.784 (6560) IO RX: C0 00 02 01 15 00 01 7B 00 00 01 01 85 01
11/03/2024 16:00:45.785 (6560) DRIVER IOReceiveBuffer(): ERROR - Command Error, Returned end-code [8501h].
11/03/2024 16:00:45.785 (5264) TAG <== (0.020) Tag(0.111.100.0).ReadValue = ERROR (hr=80004005)
11/03/2024 16:00:46.771 (6560) IO TX: 80 00 02 01 7B 00 01 15 00 01 01 01 82 00 64 00 00 01
11/03/2024 16:00:46.771 (6560) IO RX: 7B 7B C0 00 02 01 15 00 01 7B 00 01 01 01 85 01
11/03/2024 16:00:46.774 (6560) DRIVER IOReceiveBuffer(): ERROR - Command Error, Returned end-code [8501h].
11/03/2024 16:00:46.774 (5264) TAG <== (0.003) Tag(0.111.100.0).ReadValue = ERROR (hr=80004005)
Já alterei o endereço fins para todas as possíveis possibilidades. sendo que
Captura%20de%20tela%202024-03-11%20161446 Captura%20de%20tela%202024-03-11%20161702
