Hi, I’m setting up a project which consist of IEDs, HMI and a gateway. HMI will communicate with IEDs via IEC61850. After getting the status from IEDs, it will map the status to DNP 3.0 and send it to SCADA simulator. This is the problem that I found.
1 I compare the timestamp with its UTC time. It’s the same, but my timezone is GMT+7. How can I show the local time on the alarm list?
2 I’m new to the gateway setting and not familiar with DNP 3.0. This is the setting for the DNP Slave in my project.
Is there anything wrong in this setting? I cannot communicate with DNP master.
----------------------------------edit----------------------------------
I change the connection to UDP and change some settings.
Still cannot communicate. This is the capture of the requested msg.
