i am new in elipse scada i want to develope screen with symbols of pumps,blowers,pipes and tanks
how can i add this there is any library availabe in built in elips scada
Beginner in elipse scada
Hello @TALHA,
I indicate that you use Elipse E3, with it you can create library objects that can be reused as many times as necessary, both in the development application and in other applications.
In kb, we have some articles that teach its use:
- https://kb.elipse.com.br/using-libraries-in-elipse-e3-lesson-1/
- https://kb.elipse.com.br/using-libraries-in-elipse-e3-lesson-2/
- https://kb.elipse.com.br/using-libraries-in-elipse-e3-lesson-3/
- https://kb.elipse.com.br/using-libraries-in-elipse-e3-lesson-4/
- https://kb.elipse.com.br/using-libraries-in-elipse-e3-lesson-5/
- https://kb.elipse.com.br/using-libraries-in-elipse-e3-lesson-6/
- https://kb.elipse.com.br/using-libraries-in-elipse-e3-lesson-7/
- https://kb.elipse.com.br/using-libraries-in-elipse-e3-lesson-8/
Learn more about E3: https://www.elipse.com.br/en/produto/elipse-e3/
