Dear All,
i am using elipse e3 scada and sql server 2014 .
while i am any query to sql first time it will take sometime to update the result …after that its working normally…how to reduce that initial loading time
Data Updation Slow SQL to E3Browser
Good Morning @selva,
Check that the query’s CursorLocation property is set to 1-clClient.
To determine the cause, enable the FullDB log using E3 Tweak, then reproduce the test with the bank.
Submit the latest FullDB_year_month_day_x.elt and E3_year_month_day_x.elt from the “C:\eeLogs\E3” folder to gabriel@elipse.com.br.
Related supports:
