Disable Domain Related Options
Hi,
Is it possible to disable domain related options. The issue we are facing is Client can make the necessary event logging related changes without intimation to supplier and can say that data is not logging as per 21 CFR.
Looking forward to your help int his regards,
Thanking you in advance
Regards,
Suraj
Hello @surajkeer,
When you say “disable domain related options”, you mean protect the domain from edit?
If the client hasn’t this password, he can’t edit the application.
Best regards,
Link
Hi,
Domain Options which are available at the right bottom corner of our desktop which shows the license details, server runtime, etc.
Regards,
Suraj
Hello @surajkeer,
In this case you will need to configure users to allow and users to block in Permissions screen. Try to block the Edit Domain option. After that, will be necessary to log in to edit the domain.
Best regards,
Link
Hi Daniel,
Appreciate for the immediate support.
Regards,
Suraj
