E3 scada and sql data access
Good Afternoon,
i am using elipse e3 and SQL Server 2014 Standard edition.
and now database is above 9GB.
whenever we fetching data from database scada will take much time and getting not responding .after data fetching it will get ok. and user get lots of breakdown due to this problem.
i am using this script (OnShow Event and Button)
DIM F_STR,L_STR,MYTOTQRY
DIM Mday,Mmonth,Myear,Mhour,Mminute,Msecond,StartDate,EndDate,MYP,MYT
F_STR = “”
L_STR = “”
StartDate = date
Mday = Day(StartDate)
Mmonth = Month(StartDate)
Myear = Year(StartDate)
Mhour = 07’Hour(StartDate)
Mminute = 15’Minute(StartDate)
Msecond = 00’Second(StartDate)
F_STR = Myear & “/” & Mmonth & “/” & Mday & " " & Mhour & “:” & Mminute & “:” & Msecond
Mhour = 23’Hour(StartDate)
Mminute = 59’Minute(StartDate)
Msecond = 59’Second(StartDate)
L_STR = Myear & “/” & Mmonth & “/” & Mday & " " & Mhour & “:” & Mminute & “:” & Msecond
MyQry = “(E3TimeStamp >= '” & F_STR & “’ AND E3TimeStamp <= '” & L_STR & “’)”
Screen.Item(“E3Browser1”).Item(“Query1”).SetVariableValue “MyQry”,MyQry
Screen.Item(“E3Browser1”).Requery()
Please Help me…
thanks in advance…
Hi @selva!
Is the query returning any data or displaying an error message at the end?
What is the Query1’s SQL code?
hi @pgustavo ,
good morning sir.
there is no error at the end ,its returning with data only
and sql code is
SELECT (ST100.E3TimeStamp) AS InTime,ST100.InternalSerialNo,ST100.PCode,ST100.Result,PalletNo,ST100.RepairFlag,ST100.CylTm,ST100.ShaftEndPlayOK,ST100.ShaftLoadOK,ST100.ShaftEndPlayNG,ST100.ShaftLoadNG,ST100.ShaftEndPlayRT,ST100.ShaftLoadRT
FROM ST100
Where <%MyQry%>
ORDER BY ST100.E3TimeStamp Desc
Please send the E3 log file to pgustavo@elipse.com.br.
ok sir .i will send you as soon as possible.
Good Evening sir,
as per discussion i sent the mail to you.
Dear @selva ,
I suggest the following changes:
  1. SQL Code:
    FROM ST100
    Where (E3TimeStamp >= #<%F_STR%># AND E3TimeStamp <= #<%L_STR%>#)
  2. Script:
    'Screen.Item(“E3Browser1”).Item(“Query1”).SetVariableValue “MyQry”,MyQry
    Screen.Item(“E3Browser1”).Item(“Query1”).SetVariableValue “F_STR”, F_STR
    Screen.Item(“E3Browser1”).Item(“Query1”).SetVariableValue “L_STR”, L_STR
Dear @pgustavo
Thank you for your support and i will check update to you.
