It is the same with all alarm types.
I thought I had it figured out in that new alarms didn’t seem to work if added while the domain was running but worked if added when the domain was not running. That does not seem to be the case.
It is very frustrating. I have quite a few alarms defined and some work and some do not.
They are all Modbus TCP inputs discrete, digital and analog alarm types. The input changes are being seen when I look at the input under the drivers and opc headings but, the alarms do not activate inside E3.
