Hi Paulo, i am mayank’s collegue. we are developing in elipse E3 V4.8 version and we are using windows login.we dont need E3 login. Is there any possibility to hide E3 login option in login window screen under authentication?
Elipse E3 authentication option
Hi @Chintan_Vagh!
We suggest creating your own login screen using the ‘LoginWindowsUser’ method.
This method was implememented in E3 version 5.1.
Thanks for reply. As we are using Elipse E3 V4.8 so is there any possibility to create that login screen in V 4.8 ?
Unfortunately not. Upgrade is recommended in this case.
As we are updating and using v5.5, can we create own login screen with any logic method ?
Yes, you can use the following methods:
LoginUser: login operation for E3 users;
LoginWindowsUser: login operation for Windows users.
Thanks sir… One more thing i need to know. One of our client need password expiry at date change. Is it possible in v5.5 ?
Yes, you can set the number of days for the password to expire.
I can set number of days but i want expire my password at day change.
i.e. let my password expire set as 1 day then If i create my login/password today at 09/10/2020 20:00 hrs so my password should expire at 10/10/2020 00:00 hrs. Is it possible ?
No, the password expiration routine considers the entire days starting at midnight on the change date.
Hello Sir,
How are You…?? Hope everything is fine there in COVID 19 situation.
Sir, We have one query from one of our customer for password expiration on date change not as per 24 hour day calculation. Customer needs day calculate as per day change not as per 24 hours calculation. For that we have suggestion for 5.5 version from Daniel Sir.
We have 5.5 version key but yet we only get the password change pop up on day change. Password is not getting expire. Its getting expire as per its 24 hours a day calculation.
What we can do for solving the same.
We are checking and will let you know as soon as possible.
Ok sir.
Waiting for your reply.
Pls let us know once done.
Mayank
