Sub OnReportStart
dim counter
counter = 2
set pgheader = Report.Sections(“PageHeader”)
set detail = Report.Sections(“Detail”)
set screen = Application.GetFrame(“Inferior”).Screen
set check1 = screen.Item(“TUNEL01”)
set check2 = screen.Item(“TUNEL02”)
set check3 = screen.Item(“TUNEL03”)
set check4 = screen.Item(“TUNEL04”)
set check5 = screen.Item(“TUNEL05”)
set check6 = screen.Item(“TUNEL06”)
set check7 = screen.Item(“TUNEL07”)
set check8 = screen.Item(“TUNEL08”)
set check9 = screen.Item(“TUNEL09”)
set check10 = screen.Item(“TUNEL10”)
set check11 = screen.Item(“TUNEL11”)
set check12 = screen.Item(“DESOSSA”)
set check13 = screen.Item(“CE01”)
set check14 = screen.Item(“CE02”)
set check15 = screen.Item(“CMC01”)
set check16 = screen.Item(“CMC02”)
set check17 = screen.Item(“CMC03”)
set check18 = screen.Item(“CRC01”)
set check19 = screen.Item(“CRC02”)
set check20 = screen.Item(“CRC03”)
set check21 = screen.Item(“CRC04”)
set check22 = screen.Item(“CRC05”)
set check23 = screen.Item(“CRC06”)
set check24 = screen.Item(“CRC07”)
set check25 = screen.Item(“CRC08”)
set check26 = screen.Item(“CRC09”)
set check27 = screen.Item(“CRC10”)
set check28 = screen.Item(“CRC16”)
set check29 = screen.Item(“CRC17”)
if check1.Value then
detail.Controls(“Field” & CStr(counter)).Visible = true
detail.Controls(“Field” & CStr(counter)).DataField = “TUNEL01”
pgheader.Controls(“Label” & CStr(counter)).Visible = true
pgheader.Controls(“Label” & CStr(counter)).Caption = “TUNEL01”
counter = counter + 1
end if
if check2.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “TUNEL02”
pgheader.Controls(“Label” & CStr(counter)).Caption = “TUNEL02”
end if
if check3.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “TUNEL03”
pgheader.Controls(“Label” & CStr(counter)).Caption = “TUNEL03”
end if
if check4.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “TUNEL04”
pgheader.Controls(“Label” & CStr(counter)).Caption = “TUNEL04”
end if
if check5.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “TUNEL05”
pgheader.Controls(“Label” & CStr(counter)).Caption = “TUNEL05”
end if
if check6.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “TUNEL06”
pgheader.Controls(“Label” & CStr(counter)).Caption = “TUNEL06”
end if
if check7.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “TUNEL07”
pgheader.Controls(“Label” & CStr(counter)).Caption = “TUNEL07”
end if
if check8.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “TUNEL08”
pgheader.Controls(“Label” & CStr(counter)).Caption = “TUNEL08”
end if
if check9.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “TUNEL09”
pgheader.Controls(“Label” & CStr(counter)).Caption = “TUNEL09”
end if
if check10.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “TUNEL10”
pgheader.Controls(“Label” & CStr(counter)).Caption = “TUNEL10”
end if
if check11.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “TUNEL11”
pgheader.Controls(“Label” & CStr(counter)).Caption = “TUNEL11”
end if
if check12.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “DESOSSA”
pgheader.Controls(“Label” & CStr(counter)).Caption = “DESOSSA”
end if
if check13.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “CE01”
pgheader.Controls(“Label” & CStr(counter)).Caption = “CE01”
end if
if check14.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “CE02”
pgheader.Controls(“Label” & CStr(counter)).Caption = “CE02”
end if
if check15.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “CMC01”
pgheader.Controls(“Label” & CStr(counter)).Caption = “CMC01”
end if
if check16.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “CMC02”
pgheader.Controls(“Label” & CStr(counter)).Caption = “CMC02”
end if
if check17.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “CMC03”
pgheader.Controls(“Label” & CStr(counter)).Caption = “CMC03”
end if
if check18.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “CRC01”
pgheader.Controls(“Label” & CStr(counter)).Caption = “CRC01”
end if
if check19.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “CRC02”
pgheader.Controls(“Label” & CStr(counter)).Caption = “CRC02”
end if
if check20.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “CRC03”
pgheader.Controls(“Label” & CStr(counter)).Caption = “CRC03”
end if
if check21.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “CRC04”
pgheader.Controls(“Label” & CStr(counter)).Caption = “CRC04”
end if
if check22.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “CRC05”
pgheader.Controls(“Label” & CStr(counter)).Caption = “CRC05”
end if
if check23.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “CRC06”
pgheader.Controls(“Label” & CStr(counter)).Caption = “CRC06”
end if
if check24.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “CRC07”
pgheader.Controls(“Label” & CStr(counter)).Caption = “CRC07”
end if
if check25.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “CRC08”
pgheader.Controls(“Label” & CStr(counter)).Caption = “CRC08”
end if
if check26.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “CRC09”
pgheader.Controls(“Label” & CStr(counter)).Caption = “CRC09”
end if
if check27.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “CRC10”
pgheader.Controls(“Label” & CStr(counter)).Caption = “CRC10”
end if
if check28.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “CRC16”
pgheader.Controls(“Label” & CStr(counter)).Caption = “CRC16”
end if
if check29.Value then
detail.Controls(“Field” & CStr(counter)).DataField = “CRC17”
pgheader.Controls(“Label” & CStr(counter)).Caption = “CRC17”
end if
