Dear paulo,
Hope u r well & fine.
We have a situation in Elipse E3, On modbus network we have connected a PLC with 3 no’s of slaves and these slaves are capable of measuring process value and set points . we wrote a script in E3 such that when any of slave measure a process value greater than set-point this value is fetched through PLC and will activate a bit in PLC Such that it can activate hooter.
so when we are running the program and at the time when process value is above the set-point we are getting
error (HR=80004005) in E3.
please advice with the necessary solution for resolving issue.
warm regards
srikanth
