Error when control CB through IEC104M to IEC104SL/IEC61850
Dear Pro,
I have a question about IEC 104 Slave and IEC61850
In pictures, im controling CB from IEC104 Master ( IEC Test software) to Elipse Power Gateway
When i send command to gateway, the screen show 1 error message as the picture, But CB so close/open good
So how to do visible message
Thank and best regard
Hi,
How did you implement the Gateway?
Can you paste here the script that you’ve developed to treat the receiving command?
Hi,
I played default scipt of Elipse :
Sub CB.372_OnRead
Dim CMD, SE, COT, QU, SEL, MSG, SCADA
CMD = Item(“Element1”).Value ’ command value (depends on the command type)
COT = Item(“Element2”).Value ’ COT (cause of transmission)
SE = Item(“Element3”).Value ’ 1=Select, 0=Execute
QU = Item(“Element4”).Value ’ Quality of command
Application.GetObject("IEC61850.Bay372.CB.Pos.SelectWithValue").Value = CMD-1
Application.GetObject("IEC61850.Bay372.CB.Pos.Operate").Value = CMD-1
WriteEx Array(CMD, 10, SE, QU), TimeStamp 'ACTTERM
[ At the substation, I take data from IEC61850 to IEC104SL. In the Center, IEC104M send command (Close/Open CB) to station. The command is still executable
But elipse show 1 error what is script fail
Instead of using:
Application.GetObject(“IEC61850.Bay372.CB.Pos.SelectWithValue”).Value = CMD-1
Application.GetObject(“IEC61850.Bay372.CB.Pos.Operate”).Value = CMD-1
Try to use the WriteEx Method:
'WriteEx(NewValue, NewTimestamp, NewQuality)
NValue = CMD-1
Application.GetObject(“IEC61850.Bay372.CB.Pos.SelectWithValue”).WriteEx NValue,Timestamp,Quality
Application.GetObject(“IEC61850.Bay372.CB.Pos.Operate”).WriteEx NValue,Timestamp,Quality
Using this method, you can propagate the received timestamp.
Beyond that, you can try to chage the “Select/Execute command:” property to “Handl Automatically”
oh. thankyou. i used “writeEx” for the script and elipse run good.
from where to download IEC Test Software please help me
