Ethernet driver
I want to connect a single SCADA with 10-20 PLC on Ethernet driver & generate the reports for each PLC separately. Pls. help me to confirm the possibilities? Guide the same.
Dear Mahadev,
What PLCs are you going to use?
Hello,
We are going to fetch the data from Mitsubishi make PLC - FX3GE-40MT.
Please, guide.
Our MELSEC-FX driver does not support communication via Ethernet interface. The protocol implemented in the driver (QnA compatible 3E frame) works for serial communication only.
The available alternative is the Driver Mitsubishi MX, which depends on the previous installation and configuration of the “MX Component” developed by Mitsubishi.
Thanks Paulo…
We want to generate the reports for all PLC (10-20nos.) on single SCADA via Ethernet port.
PLC - FX3GE-40mt.
Each PLC will have around 100 IO / Tags.
Please, suggest the SCADA version with Ethernet Driver support. Also confirm the possibility of this requirements.
Thanks,
Mahadev
Dear Mahadev,
We have a partner in your region. He will contact you to give you more information.
how can i get driver for mitsubishi FX3ge plc
can u give the suggestion for getting driver for mitsubishi FX3ge plc
Dear @nagaraja,
You can use the Mitsubishi Melsec-FX driver for serial communication.
The Ethernet communication is possible with the Mitsubishi MX Driver, which requires the installation of the MX Component provided by Mitsubishi.
