Bom dia! Estou com dificuldade pra ler tags do CLP Micro850. Estou usando o mais atualizado Driver Allen-Bradley Micro850 v1.0.7 (IOKitLib v2.0.110). Os tags ficam cinza com quality 24. Poderiam me ajudar a entender a raiz do problema?
Gerei um log:
**29/05/2025 12:01:42.652 (15BC) DRIVER Driver name: Driver Allen-Bradley Micro850 v1.0.7 (IOKitLib v2.0.110)
29/05/2025 12:01:42.652 (15BC) DRIVER IOKitLib version 2.0.110 of Aug 21 2019 16:41:27
29/05/2025 12:01:42.652 (15BC) DRIVER drvStartComm(0,0,0,0)
29/05/2025 12:01:42.652 (15BC) DRIVER Current configuration (63 parameters):
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.Ethernet.BackupIP = ‘’
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.Ethernet.BackupIP2 = ‘’
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.Ethernet.BackupIP3 = ‘’
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.Ethernet.IPFilter = ‘’
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.Ethernet.ListenIP = ‘’
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.Ethernet.MainIP = ‘192.168.219.222’
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.Ethernet.MainPort = 44818
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.Ethernet.PingTimeoutMs = 4000
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.Ethernet.PingTries = 1
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.Ethernet.Transport = ‘TCP’
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.GiveUpTries = 1
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.Log.Enable = 1
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.Log.Filename = ‘C:\ABMicro850.log’
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.RAS.ATCommand = ‘’
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.RecoverEnable = 1
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.RecoverPeriodSec = 20
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.Serial.Baudrate = 9600
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.Serial.DataBits = 8
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.Serial.Port = 1
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.TAPI.ModemID = 4294967295
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.TAPI.PhoneNumber = ‘’
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.TimeoutMs = 1000
29/05/2025 12:01:42.652 (15BC) DRIVER - IO.Type = ‘Ethernet’
29/05/2025 12:01:42.652 (15BC) DRIVER - 40 parameters with value = 0 were omitted
29/05/2025 12:01:42.652 (0F8C) IOKIT INITIALIZING…
29/05/2025 12:01:42.652 (0F8C) SOCKET Winsock initialized: version=2.2, highVersion=2.2
29/05/2025 12:01:42.652 (0F8C) IOKIT INITIALIZED!
29/05/2025 12:01:42.652 (0F8C) IOKIT Request handler enabled
29/05/2025 12:01:42.652 (0F8C) IOKIT CONNECTING…
29/05/2025 12:01:42.652 (0F8C) SOCKET connecting socket to ‘192.168.219.222’ on port 44818…
29/05/2025 12:01:42.652 (188C) TAG Tag(‘BC_EEEB9_1_HABHP’).Validate = SUCCESS (type=10;flags=9)
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_BP
').Validate = SUCCESS (type=10;flags=9)
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_INTERT
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_AM
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_LDM
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_LDA
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_LR
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_FAL
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_LGN
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_DLN
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_ON
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_NET
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_RST
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_TIPSP
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_MTRA
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_HTRA
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_TRST
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_MTIRST
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_MBQERRO
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_CMDSEL
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_SEL
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_MTISP
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_MV
29/05/2025 12:01:42.652 (188C) TAG Tag('BC_EEEB9_1_HABMB
29/05/2025 12:01:42.652 (188C) TAG Tag('MB_BC_EEEB9_1_RET
29/05/2025 12:01:42.652 (188C) TAG Tag('MB_BC_EEEB9_1_AC
29/05/2025 12:01:42.652 (188C) TAG Tag('MB_BC_EEEB9_1_RMP
29/05/2025 12:01:42.652 (188C) TAG Tag('MB_BC_EEEB9_1_RMD
29/05/2025 12:01:42.652 (188C) TAG Tag('MB_BC_EEEB9_1_FAL
29/05/2025 12:01:42.667 (0F8C) SOCKET socket connected to ‘192.168.219.222’ on port 44818 (local port 63222)!
29/05/2025 12:01:42.667 (0F8C) IOKIT CONNECTED!
29/05/2025 12:01:42.683 (15BC) DRIVER Register Connection
29/05/2025 12:01:42.683 (0F8C) IO TX: 65 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00
29/05/2025 12:01:42.901 (0F8C) IO RX: 65 00 04 00 6C C9 16 97 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00
29/05/2025 12:01:42.901 (15BC) DRIVER Connect Message
29/05/2025 12:01:42.901 (0F8C) IO TX: 6F 00 3E 00 6C C9 16 97 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 00 02 00 00 00 00 00 B2 00 2E 00 54 02 20 06 24 01 05 F7 02 00 00 00 01 00 00 00 72 00 4B 54 C0 64 64 97 02 00 00 00 80 84 1E 00 F8 43 80 84 1E 00 F8 43 A3 02 20 02 24 01
29/05/2025 12:01:42.964 (0F8C) IO RX: 6F 00 2E 00 6C C9 16 97 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 02 00 00 00 00 00 B2 00 1E 00 D4 00 00 00 E1 4A 00 00 01 00 00 00 72 00 4B 54 C0 64 64 97 80 84 1E 00 80 84 1E 00 00 00
29/05/2025 12:01:42.964 (0F8C) IO TX: 6F 00 16 00 6C C9 16 97 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 00 02 00 00 00 00 00 B2 00 06 00 01 02 20 01 24 01
29/05/2025 12:01:43.026 (0F8C) IO RX: 6F 00 3E 00 6C C9 16 97 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 02 00 00 00 00 00 B2 00 2E 00 81 00 00 00 01 00 0E 00 03 01 0C 0C 34 00 78 56 34 12 10 32 30 38 30 2D 4C 43 35 30 2D 34 38 51 57 42 53 03 00 00 00 65 6E 67 65 6E 67 00
29/05/2025 12:01:43.026 (15BC) DRIVER DeviceInfo: VendorID=1 ProductType=14 ProductCode=259 Revision=12.12 SerialNumber=12345678 ProductName=2080-LC50-48QWBS
29/05/2025 12:01:43.026 (15BC) DRIVER Read: BC_EEEB9_1_HABHP
29/05/2025 12:01:43.026 (0F8C) IO TX: 70 00 30 00 6C C9 16 97 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E9 07 02 00 A1 00 04 00 E1 4A 00 00 B1 00 1C 00 00 00 52 09 91 10 42 43 5F 45 45 45 42 39 5F 31 5F 48 41 42 48 50 01 00 00 00 00 00
29/05/2025 12:01:44.058 (0F8C) IO RX: TIMEOUT
29/05/2025 12:01:44.058 (15BC) DRIVER Error: Failed SendReceive
29/05/2025 12:01:44.058 (15BC) TAG <== (1.389) Tag(‘BC_EEEB9_1_HABHP’).ReadValue = ERROR (hr=80004005)
29/05/2025 12:01:44.058 (15BC) DRIVER Read: BC_EEEB9_1_BP
29/05/2025 12:01:44.058 (0F8C) IO TX: 70 00 30 00 6C C9 16 97 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E9 07 02 00 A1 00 04 00 E1 4A 00 00 B1 00 1C 00 01 00 52 09 91 0F 42 43 5F 45 45 45 42 39 5F 31 5F 42 50 0D 0A 00 01 00 00 00 00 00
29/05/2025 12:01:44.182 (0F8C) IO RX: 70 00 1A 00 6C C9 16 97 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 A1 00 04 00 01 00 00 00 B1 00 06 00 01 00 D2 00 05 00
29/05/2025 12:01:44.182 (15BC) DRIVER SendUnitData, Status Error = 5 The particular item referenced (usually instance) could not be found!
29/05/2025 12:01:44.182 (15BC) TAG <== (0.127) Tag('BC_EEEB9_1_BP
').ReadValue = ERROR (hr=80004005)
29/05/2025 12:01:44.182 (15BC) DRIVER Read: BC_EEEB9_1_INTERT
29/05/2025 12:01:44.182 (0F8C) IO TX: 70 00 34 00 6C C9 16 97 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E9 07 02 00 A1 00 04 00 E1 4A 00 00 B1 00 20 00 02 00 52 0B 91 13 42 43 5F 45 45 45 42 39 5F 31 5F 49 4E 54 45 52 54 0D 0A 00 01 00 00 00 00 00
29/05/2025 12:01:44.214 (0F8C) IO RX: 70 00 1A 00 6C C9 16 97 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 A1 00 04 00 01 00 00 00 B1 00 06 00 02 00 D2 00 05 00
29/05/2025 12:01:44.214 (15BC) DRIVER SendUnitData, Status Error = 5 The particular item referenced (usually instance) could not be found!
29/05/2025 12:01:44.214 (15BC) TAG <== (0.028) Tag('BC_EEEB9_1_INTERT
29/05/2025 12:01:44.214 (15BC) DRIVER Read: BC_EEEB9_1_AM
29/05/2025 12:01:44.214 (0F8C) IO TX: 70 00 30 00 6C C9 16 97 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E9 07 02 00 A1 00 04 00 E1 4A 00 00 B1 00 1C 00 03 00 52 09 91 0F 42 43 5F 45 45 45 42 39 5F 31 5F 41 4D 0D 0A 00 01 00 00 00 00 00
29/05/2025 12:01:44.362 (0F8C) IO RX: 70 00 1A 00 6C C9 16 97 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 A1 00 04 00 01 00 00 00 B1 00 06 00 03 00 D2 00 05 00
29/05/2025 12:01:44.362 (15BC) DRIVER SendUnitData, Status Error = 5 The particular item referenced (usually instance) could not be found!
29/05/2025 12:01:44.362 (15BC) TAG <== (0.155) Tag('BC_EEEB9_1_AM
29/05/2025 12:01:44.362 (15BC) DRIVER Read: BC_EEEB9_1_LDM
29/05/2025 12:01:44.362 (0F8C) IO TX: 70 00 30 00 6C C9 16 97 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E9 07 02 00 A1 00 04 00 E1 4A 00 00 B1 00 1C 00 04 00 52 09 91 10 42 43 5F 45 45 45 42 39 5F 31 5F 4C 44 4D 0D 0A 01 00 00 00 00 00
29/05/2025 12:01:44.401 (0F8C) IO RX: 70 00 1A 00 6C C9 16 97 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 A1 00 04 00 01 00 00 00 B1 00 06 00 04 00 D2 00 05 00
29/05/2025 12:01:44.401 (15BC) DRIVER SendUnitData, Status Error = 5 The particular item referenced (usually instance) could not be found!
29/05/2025 12:01:44.401 (15BC) TAG <== (0.047) Tag('BC_EEEB9_1_LDM
