How to Convert Numbers to Word in report ?
For example
1 = one
1 = หนึ่ง (ThaiLanguage)
For example
1 = one
@Nitipat_Sakunwongsal, good day.
You’ll have to use scripts for this.
Here is an example with a Label object on PageHeader:
Sub OnBeforePrint
Number = 100
Report.Sections("PageHeader").Controls("Label1").Caption = Words_1_all(Number)
' Return words for this value between 1 and 999.
Private Function Words_1_999(num)
Dim hundreds
Dim remainder
Dim result
hundreds = num \ 100
remainder = num - hundreds * 100
If hundreds > 0 Then
result = Words_1_19(hundreds) & " hundred "
If remainder > 0 Then
result = result & Words_1_99(remainder)
Words_1_999 = Trim(result)
End Function
' Return a word for this value between 1 and 19.
Private Function Words_1_19(num)
Select Case num
Case 1
Words_1_19 = "one"
Case 2
Words_1_19 = "two"
Case 3
Words_1_19 = "three"
Case 4
Words_1_19 = "four"
Case 5
Words_1_19 = "five"
Case 6
Words_1_19 = "six"
Case 7
Words_1_19 = "seven"
Case 8
Words_1_19 = "eight"
Case 9
Words_1_19 = "nine"
Case 10
Words_1_19 = "ten"
Case 11
Words_1_19 = "eleven"
Case 12
Words_1_19 = "twelve"
Case 13
Words_1_19 = "thirteen"
Case 14
Words_1_19 = "fourteen"
Case 15
Words_1_19 = "fifteen"
Case 16
Words_1_19 = "sixteen"
Case 17
Words_1_19 = "seventeen"
Case 18
Words_1_19 = "eightteen"
Case 19
Words_1_19 = "nineteen"
End Select
End Function
' Return a word for this value between 1 and 99.
Private Function Words_1_99(num)
Dim result
Dim tens
tens = num \ 10
If tens <= 1 Then
' 1 <= num <= 19
result = result & " " & Words_1_19(num)
Else
' 20 <= num
' Get the tens digit word.
Select Case tens
Case 2
result = "twenty"
Case 3
result = "thirty"
Case 4
result = "forty"
Case 5
result = "fifty"
Case 6
result = "sixty"
Case 7
result = "seventy"
Case 8
result = "eighty"
Case 9
result = "ninety"
End Select
' Add the ones digit number.
result = result & " " & Words_1_19(num - tens * 10)
Words_1_99 = Trim(result)
End Function
' Return a string of words to represent the
' integer part of this value.
Private Function Words_1_all(num)
Dim power_value(5)
Dim power_name(5)
Dim digits
Dim result
Dim i
' Initialize the power names and values.
power_name(1) = "trillion": power_value(1) = 1000000000000
power_name(2) = "billion": power_value(2) = 1000000000
power_name(3) = "million": power_value(3) = 1000000
power_name(4) = "thousand": power_value(4) = 1000
power_name(5) = "": power_value(5) = 1
For i = 1 To 5
' See if we have digits in this range.
If num >= power_value(i) Then
' Get the digits.
digits = Int(num / power_value(i))
' Add the digits to the result.
If Len(result) > 0 Then result = result & ", "
result = result & _
Words_1_999(digits) & _
" " & power_name(i)
' Get the number without these digits.
num = num - digits * power_value(i)
Next
Words_1_all = Trim(result)
End Function
Sub Empty()
Result:
This script has been adapted from this page.
Thank you very much
