Hi Team.
Query for Key Board provided by elipse (we are using 4.8 version)
(1) I have query for key board provide by elipse in 4.8 version. We found issue in identify the caps lock is on or off. Due to this user passwords gets block on regular basis.
Provide solution for the same as we found difficult to identify from elipse key board that weather caps lock is on or off.
Another query is related to users. (We are using 5.5 version of E3)
(1) We need user list who are made by admin in run time.
(2) There is option of NEW / EDIT / REMOVE for users. We want to disable the REMOVE option from SCADA. How to do this. We does not want to remove the user once it created by admin.
Provide the solution at the earliest for both queries.
Thank in Advance…!!
With Regards,
John
