Dear Sir/Madam,
I am having problem with defining Tag due having Problem with downloading from the Elipse Website. Please guide me with the Tag(N1 - N4).
Regards
Bikash Mohanty
9938857050,7210978247
Dear Sir/Madam,
Regards
Bikash Mohanty
Dear Bikash,
The description of the N/B parameters is as follows:
N1/B1: Not used, it must be kept in 0 (zero).
N2/B2: Data Type and Area. This value must be composed by the sum of data types plus this Area (N2/B2 = Type Value + Area Value). If Data Type value is 0 (zero), then assumes Area’s default data type.
N3/B3: Special usage parameter. Leave it in 0 (zero) if Area’s address, or offset, is less than 65535 and there is no need to inform the size if it is a String type (otherwise, please check topic Using the N3/B3 Parameter).
N4/B4: Address value in this Area, or offset, for values up to 65535 (if greater than this value, please check topic Using the N3/B3 Parameter).
Please try downloading again and let me know if you have succeeded or not.
