Olá, estou tentando fazer a comunicação do elipse power com um driver DNP3. Consigo pingar e comunicar via modbus com o IED, mas via DNP3 não consigo. Como o log não retorna nenhuma mensagem compreensível de erro, não sei o que pode ser, uma vez que a configuração está semelhante a de outros IEDs. Segue log da tentativa:
Obs: Coloquei uma tag com N2 = -21 para verificar o estado do endereço N1.
27/03/2023 17:35:43.443 (0754) DRIVER Driver name: Driver DNP 3.0 Master v4.0.45 (IOKitLib v2.0.126)
27/03/2023 17:35:43.443 (0754) DRIVER IOKitLib version 2.0.126 of Mar 29 2022 07:22:42
27/03/2023 17:35:43.443 (0754) DRIVER Current configuration (109 parameters):
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.AcceptMsgNotRequested = 1
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.AcceptMsgOutOfSequence = 1
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.analog_deadband = 1
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.App_retries = 3
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.App_timeout = 3000
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.App_Write_retries = 3
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.cblock_qualifier = 40
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.counter_deadband = 1
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.DefaultSlaveAddress = 1
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.DemotionTime = 10
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.ErrorCount = 1
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.ProTogether = 1
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.relay_offtime = 500
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.relay_ontime = 500
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.RWSyncTSFilePath = '\DNPSYNCTS.TS'
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.ScanClass0Time = 120000
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.ScanEventsTime = 1000
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.select_operate_tout = 10
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.source_address = 1
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.UseCallbacks = 1
27/03/2023 17:35:43.443 (0754) DRIVER - DNP.UseTimeZone = 1
27/03/2023 17:35:43.443 (0754) DRIVER - IO.Ethernet.BackupIP = ''
27/03/2023 17:35:43.443 (0754) DRIVER - IO.Ethernet.BackupIP2 = ''
27/03/2023 17:35:43.443 (0754) DRIVER - IO.Ethernet.BackupIP3 = ''
27/03/2023 17:35:43.443 (0754) DRIVER - IO.Ethernet.IPFilter = ''
27/03/2023 17:35:43.443 (0754) DRIVER - IO.Ethernet.ListenIP = ''
27/03/2023 17:35:43.443 (0754) DRIVER - IO.Ethernet.MainIP = '10.168.13.126'
27/03/2023 17:35:43.443 (0754) DRIVER - IO.Ethernet.MainPort = 20001
27/03/2023 17:35:43.443 (0754) DRIVER - IO.Ethernet.PingTimeoutMs = 4000
27/03/2023 17:35:43.443 (0754) DRIVER - IO.Ethernet.PingTries = 1
27/03/2023 17:35:43.443 (0754) DRIVER - IO.Ethernet.Transport = 'TCP'
27/03/2023 17:35:43.443 (0754) DRIVER - IO.GiveUpTries = 1
27/03/2023 17:35:43.443 (0754) DRIVER - IO.InactivityEnable = 1
27/03/2023 17:35:43.443 (0754) DRIVER - IO.InactivityPeriodSec = 30
27/03/2023 17:35:43.443 (0754) DRIVER - IO.Log.Enable = 1
27/03/2023 17:35:43.443 (0754) DRIVER - IO.Log.Filename = 'C:\eeLogs\DNPMaster_%DATE%.log'
27/03/2023 17:35:43.443 (0754) DRIVER - IO.RecoverEnable = 1
27/03/2023 17:35:43.443 (0754) DRIVER - IO.RecoverPeriodSec = 20
27/03/2023 17:35:43.443 (0754) DRIVER - IO.Serial.Baudrate = 9600
27/03/2023 17:35:43.443 (0754) DRIVER - IO.Serial.DataBits = 8
27/03/2023 17:35:43.443 (0754) DRIVER - IO.Serial.Port = 1
27/03/2023 17:35:43.443 (0754) DRIVER - IO.TimeoutMs = 3000
27/03/2023 17:35:43.443 (0754) DRIVER - IO.Type = 'Ethernet'
27/03/2023 17:35:43.443 (0754) DRIVER - 66 parameters with value = 0 were omitted
27/03/2023 17:35:43.443 (0754) DRIVER drvSetStatus('LOG') = ON
27/03/2023 17:35:43.583 (0754) DRIVER drvGetStatus('LOGFILE') = 'C:\eeLogs\DNPMaster_%DATE%.log'
27/03/2023 17:35:43.583 (0754) DRIVER drvGetStatus('LOG') = 1 (ON)
27/03/2023 17:35:44.817 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:35:44.833 (06E8) DRIVER Retrying Communication 3/3
27/03/2023 17:35:44.833 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:35:45.723 (1080) IO RX: 05 64 0A 44 02 00 01 00 10 F0 FD FD 82 82 08 73 3A
27/03/2023 17:35:47.848 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:35:47.863 (06E8) TAG <== (12.141) Tag(0.1.102.1).ReadValue = ERROR (hr=80004005)
27/03/2023 17:35:47.863 (06E8) TAG <== (0.000) Tag(0.65515.0.0).ReadValue = (17:35:47.863) 0
27/03/2023 17:35:47.863 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:35:50.722 (1080) IO RX: 05 64 0A 44 02 00 01 00 10 F0 FE FE 82 82 08 38 55
27/03/2023 17:35:50.878 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:35:50.894 (06E8) DRIVER Retrying Communication 1/3
27/03/2023 17:35:50.894 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:35:53.909 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:35:53.925 (06E8) DRIVER Retrying Communication 2/3
27/03/2023 17:35:53.925 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:35:55.752 (1080) IO RX: 05 64 0A 44 02 00 01 00 10 F0 FF FF 82 82 08 D6 B4
27/03/2023 17:35:56.940 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:35:56.955 (06E8) DRIVER Retrying Communication 3/3
27/03/2023 17:35:56.955 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:35:59.970 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:35:59.986 (06E8) TAG <== (12.122) Tag(0.1.102.1).ReadValue = ERROR (hr=80004005)
27/03/2023 17:35:59.986 (06E8) TAG <== (0.000) Tag(0.65515.0.0).ReadValue = (17:35:59.986) 0
27/03/2023 17:35:59.986 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:36:00.720 (1080) IO RX: 05 64 0A 44 02 00 01 00 10 F0 C0 F0 82 82 08 07 99
27/03/2023 17:36:03.001 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:36:03.016 (06E8) DRIVER Retrying Communication 1/3
27/03/2023 17:36:03.016 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:36:05.735 (1080) IO RX: 05 64 0A 44 02 00 01 00 10 F0 C1 F1 82 82 08 E9 78
27/03/2023 17:36:06.031 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:36:06.047 (06E8) DRIVER Retrying Communication 2/3
27/03/2023 17:36:06.047 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:36:09.062 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:36:09.078 (06E8) DRIVER Retrying Communication 3/3
27/03/2023 17:36:09.078 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:36:10.718 (1080) IO RX: 05 64 0A 44 02 00 01 00 10 F0 C2 F2 82 82 08 A2 17
27/03/2023 17:36:12.093 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:36:12.108 (06E8) TAG <== (12.122) Tag(0.1.102.1).ReadValue = ERROR (hr=80004005)
27/03/2023 17:36:12.108 (06E8) TAG <== (0.000) Tag(0.65515.0.0).ReadValue = (17:36:12.108) 0
27/03/2023 17:36:12.108 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:36:15.123 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:36:15.139 (06E8) DRIVER Retrying Communication 1/3
27/03/2023 17:36:15.139 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:36:15.717 (1080) IO RX: 05 64 0A 44 02 00 01 00 10 F0 C3 F3 82 82 08 4C F6
27/03/2023 17:36:18.154 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:36:18.169 (06E8) DRIVER Retrying Communication 2/3
27/03/2023 17:36:18.169 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:36:20.716 (1080) IO RX: 05 64 0A 44 02 00 01 00 10 F0 C4 F4 82 82 08 34 C9
27/03/2023 17:36:21.184 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:36:21.200 (06E8) DRIVER Retrying Communication 3/3
27/03/2023 17:36:21.200 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:36:24.215 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:36:24.231 (06E8) TAG <== (12.122) Tag(0.1.102.1).ReadValue = ERROR (hr=80004005)
27/03/2023 17:36:24.231 (06E8) TAG <== (0.000) Tag(0.65515.0.0).ReadValue = (17:36:24.231) 0
27/03/2023 17:36:24.231 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:36:25.715 (1080) IO RX: 05 64 0A 44 02 00 01 00 10 F0 C5 F5 82 82 08 DA 28
27/03/2023 17:36:27.246 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:36:27.261 (06E8) DRIVER Retrying Communication 1/3
27/03/2023 17:36:27.261 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:36:30.276 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:36:30.292 (06E8) DRIVER Retrying Communication 2/3
27/03/2023 17:36:30.292 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:36:30.714 (1080) IO RX: 05 64 0A 44 02 00 01 00 10 F0 C6 F6 82 82 08 91 47
27/03/2023 17:36:33.307 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:36:33.322 (06E8) DRIVER Retrying Communication 3/3
27/03/2023 17:36:33.322 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:36:35.713 (1080) IO RX: 05 64 0A 44 02 00 01 00 10 F0 C7 F7 82 82 08 7F A6
27/03/2023 17:36:36.337 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:36:36.353 (06E8) TAG <== (12.122) Tag(0.1.102.1).ReadValue = ERROR (hr=80004005)
27/03/2023 17:36:36.353 (06E8) TAG <== (0.000) Tag(0.65515.0.0).ReadValue = (17:36:36.353) 0
27/03/2023 17:36:36.353 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:36:39.368 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:36:39.384 (06E8) DRIVER Retrying Communication 1/3
27/03/2023 17:36:39.384 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:36:40.727 (1080) IO RX: 05 64 0A 44 02 00 01 00 10 F0 C8 F8 82 82 08 61 39
27/03/2023 17:36:42.399 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:36:42.414 (06E8) DRIVER Retrying Communication 2/3
27/03/2023 17:36:42.414 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:36:45.429 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:36:45.444 (06E8) DRIVER Retrying Communication 3/3
27/03/2023 17:36:45.444 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:36:45.725 (1080) IO RX: 05 64 0A 44 02 00 01 00 10 F0 C9 F9 82 82 08 8F D8
27/03/2023 17:36:48.459 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:36:48.475 (06E8) TAG <== (12.122) Tag(0.1.102.1).ReadValue = ERROR (hr=80004005)
27/03/2023 17:36:48.475 (06E8) TAG <== (0.000) Tag(0.65515.0.0).ReadValue = (17:36:48.475) 0
27/03/2023 17:36:48.475 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:36:50.724 (1080) IO RX: 05 64 0A 44 02 00 01 00 10 F0 CA FA 82 82 08 C4 B7
27/03/2023 17:36:51.490 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:36:51.505 (06E8) DRIVER Retrying Communication 1/3
27/03/2023 17:36:51.505 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:36:54.520 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:36:54.536 (06E8) DRIVER Retrying Communication 2/3
27/03/2023 17:36:54.536 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:36:55.723 (1080) IO RX: 05 64 0A 44 02 00 01 00 10 F0 CB FB 82 82 08 2A 56
27/03/2023 17:36:57.551 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:36:57.566 (06E8) DRIVER Retrying Communication 3/3
27/03/2023 17:36:57.566 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:37:00.581 (06E8) DRIVER SendDllOnlyFrame 1
27/03/2023 17:37:00.597 (06E8) TAG <== (12.122) Tag(0.1.102.1).ReadValue = ERROR (hr=80004005)
27/03/2023 17:37:00.597 (06E8) TAG <== (0.000) Tag(0.65515.0.0).ReadValue = (17:37:00.597) 0
27/03/2023 17:37:00.597 (1080) IO TX: 05 64 05 C0 01 00 01 00 DF 53
27/03/2023 17:37:00.722 (1080) IO RX: 05 64 0A 44 02 00 01 00 10 F0 CC FC 82 82 08 52 69
27/03/2023 17:37:03.362 (0754) DRIVER drvSetStatus('LOG') = OFF
