Estou utilizando o driver do Micro850 da Rockwell. Ao inserir uma TAG de comunicação com o meso nome da variável global no meu CLP, o Elipse não consgeue retornar o valor contido nela.
Segue o LOG de conexão:
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | Driver name: Driver Allen-Bradley Micro850 v1.0.7 (IOKitLib v2.0.110) |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | IOKitLib version 2.0.110 of Aug 21 2019 16:41:27 |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | drvStartComm(0,0,0,0) |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | Current configuration (49 parameters): |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.Ethernet.BackupIP = ‘’ |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.Ethernet.BackupIP2 = ‘’ |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.Ethernet.BackupIP3 = ‘’ |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.Ethernet.IPFilter = ‘’ |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.Ethernet.ListenIP = ‘’ |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.Ethernet.MainIP = ‘10.0.13.18’ |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.Ethernet.MainPort = 44818 |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.Ethernet.PingTimeoutMs = 4000 |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.Ethernet.PingTries = 1 |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.Ethernet.Transport = ‘TCP’ |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.GiveUpTries = 1 |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.Log.Enable = 1 |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.Log.Filename = ‘C:\eeLogs\MICRO850_%DATE%.log’ |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.RecoverEnable = 1 |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.RecoverPeriodSec = 20 |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.Serial.Baudrate = 9600 |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.Serial.DataBits = 8 |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.Serial.Port = 1 |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.TimeoutMs = 1000 |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - IO.Type = ‘Ethernet’ |
| 25/06/2020 11:58:49.980 (0F5C) DRIVER | - 29 parameters with value = 0 were omitted |
| 25/06/2020 11:58:49.980 (1434) IOKIT | INITIALIZING… |
| 25/06/2020 11:58:49.980 (1434) SOCKET | Winsock initialized: version=2.2, highVersion=2.2 |
| 25/06/2020 11:58:49.980 (1434) IOKIT | INITIALIZED! |
| 25/06/2020 11:58:49.980 (1434) IOKIT | Request handler enabled |
| 25/06/2020 11:58:49.980 (1434) IOKIT | CONNECTING… |
| 25/06/2020 11:58:49.980 (1434) SOCKET | connecting socket to ‘10.0.13.18’ on port 44818… |
| 25/06/2020 11:58:49.983 (1434) SOCKET | socket connected to ‘10.0.13.18’ on port 44818 (local port 49401)! |
| 25/06/2020 11:58:49.983 (1434) IOKIT | CONNECTED! |
| 25/06/2020 11:59:14.503 (0F5C) TAG | Tag(0.0.0.0).Validate = SUCCESS (type=10;flags=9) |
| 25/06/2020 11:59:14.503 (0F5C) DRIVER | Empty Item Parameter |
| 25/06/2020 11:59:14.503 (0F5C) TAG | <== (0.000) Tag(0.0.0.0).ReadValue = ERROR (hr=80004005) |
| 25/06/2020 11:59:15.603 (0F5C) DRIVER | Empty Item Parameter |
| 25/06/2020 11:59:15.603 (0F5C) TAG | <== (0.000) Tag(0.0.0.0).ReadValue = ERROR (hr=80004005) |
| 25/06/2020 11:59:16.603 (0F5C) DRIVER | Empty Item Parameter |
| 25/06/2020 11:59:16.603 (0F5C) TAG | <== (0.000) Tag(0.0.0.0).ReadValue = ERROR (hr=80004005) |
| 25/06/2020 11:59:17.603 (0F5C) DRIVER | Empty Item Parameter |
| 25/06/2020 11:59:17.603 (0F5C) TAG | <== (0.000) Tag(0.0.0.0).ReadValue = ERROR (hr=80004005) |
| 25/06/2020 11:59:18.603 (0F5C) DRIVER | Empty Item Parameter |
| 25/06/2020 11:59:18.603 (0F5C) TAG | <== (0.000) Tag(0.0.0.0).ReadValue = ERROR (hr=80004005) |
