Boa tarde!
Minha aplicação está apresentado o mesmo problema apresentado neste tópico.
Veja os scripts que usei para gerar o relatório.
Script no relatório:
Sub OnBeforePrint
set Chart = Report.Sections(“PageHeader”).Controls(“E3Chart1”)
set ChartTela = Application.GetFrame(“QuadroCentral”).Screen.Item(“E3Chart1”)
Chart.CopyConfig(ChartTela)
Chart.LoadData()
Chama o relatório:
Sub Figura2_Click()
auxDataInicial = Screen.Item(“spDataInicial”).Value
auxDataFinal = Screen.Item(“spDataFinal”).Value
set E3Chart = Screen.Item(“E3Chart1”)
set Report = Application.LoadReport("[Relatórios].ConsumoMTC")
Report.Item(“Consulta1”).SetVariableValue “FilDataInicial”, auxDataInicial
Report.Item(“Consulta1”).SetVariableValue “FilDataFinal”, auxDataFinal
Report.PrintPreview()
A consulta do relatório está funcionando corretamente, inclusive é a mesma configuração/script utilizado para mostrar o gráfico na tela.
SELECT
CAST(FLOOR(CAST(E3TimeStamp as float)) as datetime) as Dia,
SUM(MM1Diff) as MM1,
SUM(MM2Diff) as MM2,
SUM(MM3Diff) as MM3,
SUM(MM4Diff) as MM4,
SUM(MM5Diff) as MM5,
SUM(MMTDiff) as MMT
FROM (SELECT E3TimeStamp
/* MM-01 /
,[MM1]
,[MM1] - (
SELECT TOP 1 [MM1]
FROM [MTC_CF_MM] b
WHERE a.E3TimeStamp > b.E3TimeStamp
ORDER BY b.E3TimeStamp DESC) as MM1Diff
/ MM-02 /
,[MM2]
,[MM2] - (
SELECT TOP 1 [MM2]
FROM [MTC_CF_MM] b
ORDER BY b.E3TimeStamp DESC) as MM2Diff
/ MM-03 /
,[MM3]
,[MM3] - (
SELECT TOP 1 [MM3]
FROM [MTC_CF_MM] b
ORDER BY b.E3TimeStamp DESC) as MM3Diff
/ MM-04 /
,[MM4]
,[MM4] - (
SELECT TOP 1 [MM4]
FROM [MTC_CF_MM] b
ORDER BY b.E3TimeStamp DESC) as MM4Diff
/ MM-05 /
,[MM5]
,[MM5] - (
SELECT TOP 1 [MM5]
FROM [MTC_CF_MM] b
ORDER BY b.E3TimeStamp DESC) as MM5Diff
/ MM-T /
,[MMT]
,[MMT] - (
SELECT TOP 1 [MMT]
FROM [MTC_CF_MM] b
ORDER BY b.E3TimeStamp DESC) as MMTDiff
FROM [MTC_CF_MM] a) as DIFERENCA
WHERE ( DIFERENCA.E3TimeStamp >= #<%FilDataInicial%># AND DIFERENCA.E3TimeStamp <= #<%FilDataFinal%># )
/ WHERE ( MTC_CF_MM.E3TimeStamp >= #<%FilDataInicial%># AND MTC_CF_MM.E3TimeStamp <= #<%FilDataFinal%># ) */
GROUP BY CAST(FLOOR(CAST(E3TimeStamp as float)) as datetime)
Quando visualizo o relatório, aparecem as legenda, conforme as penas selecionadas, as escalas dos eixos aparecem conforme mostrado na tela da aplicação, mas o gráfico fica em branco.
Utilizo penas históricas e a versão do elipse é a 4.8.352
