Good Morning,
Please suggest me is how to send sms without gsm modem .
SMS Without GSM Modem
Hi @selva!
The solution offered by Elipse Software requires a GSM modem.
Alternatively, you can use a web service that sends SMS messages. Communication between E3 and the web service can be done by script, using the ServerXMLHTTP object.
hi good evening,
i understand can u share me a any sample .pls help me.
thank you in advance…
have a good day…
You can try this one:
Example script:
Sub CommandButton6_Click()
apikey = "Your API key"
message = "This is your message"
numbers = "Destination phone number"
sender = "Your sender name"
url = "http://api.txtlocal.com/send/?apikey=" & apikey & "&numbers=" & numbers & "&message=" & message & "&sender=" & sender
set xmlhttp = CreateObject("MSXML2.ServerXMLHTTP")
xmlhttp.open "POST", url, false
xmlhttp.send ""
MsgBox xmlhttp.responseText
set xmlhttp = nothing
Note: You will need to contact their technical support to enable sending international messages. I suggest that you look for some web service in your country.
Try this:
Good Afternoon,
thanks a lot for your support. i will check and update you…
thank you so much.
Try SMS services without GSM modem with Gunisms, We provide free 20 SMS. https://www.gunisms.com.au/free-sms-service
