Same as picture, In topology, direction of the Switch at the side of the Earth switch. But when i run project, direction of the Switch is reversed. Can you fix it?
ths,
Hi @anhquoc1103!
In Screen, you can change the BladePosition property of switches. Just click on the desired switch (left button), and change value of the property. Look at the images bellow:
thank Fonseca…
