Hi,
i am trying to split text file like paragraph by paragraph using FSO Method,But I am failed ,pls suggest me a good way to do that…
Text File Spliting
hi there, can u show a piece of ur text? until then maybe this code can help you.
Sub Foo()
Const ForReading = 1
Dim arr
Dim i
Dim file
Dim fso
Set fso = CreateObject("Scripting.FileSystemObject")
Set file = fso.OpenTextFile("c:\temp\test.txt", ForReading)
content = file.ReadAll
arr = Split(content, vbTab)
For i = 1 To UBound(arr)
MsgBox i & ": " & arr( i )
Next
Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor
incididunt ut labore et dolore magna aliqua.
Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex
ea commodo consequat.
Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat
nulla pariatur.
Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt
mollit anim id est laborum.
Hi @selva!
You can use ‘Chr(10)’ as delimiter in the Split method. For example:
Dim fso, f, a
Set f = fso.OpenTextFile("filename.txt", 1)
a = Split(f.ReadAll, Chr(10))
for i=0 to UBound(a,1)
MsgBox a(i)
next
thank you very much…sorry for late updation
