We have create a report module in which we are unable to insert data grid object and date time picker object by using Date and Time picker .ocx file of VB 6.0 version. and Microsoft Data Grid .ocx … the following error have occurred during the creation. please suggest for clearing the Error.
Unable to insert Data-grid and Date time picker in E3 using activex control option with MSDATGRD.OCX & Date and time picker.OCX
Dear Srikanth,
This error indicates the ActiveX being inserted is not licensed in your PC.
Related article:
http://kb.elipse.com.br/en-us/questions/4225
Dear paulo,
Thanks for your reply…
As you said we already had licences for the same, this error is not similar for all the screens i.e when we took another screen and tried for insertion of Activex objects there we are able to get the it with out any error … only for particular screen we are getting this error.
Dear paulo,
the above problem is resolved now, but we are unable to open the screen in which we have placed the Activex objects… when we are trying to open it is opening with a blank screen properties as shown in attached image.
please suggest solution for the same…
warm regards
srikanth
This is probably for the same reason. We can confirm with the E3 logs.
You can check the description of the error code in the link below.
