When adding a block group, only the first data can be displayed, but the subsequent IP address data cannot be displayed. How can I make the block group be displayed continuously.Protocol 104 is used
Hi @lin , sorry for my poor english, but I try to help…
In the column “Size/Index” of the image you have attached, you have the number 2. This number means the size of this block in my opinion.
Here, I use this number as a sum off all elements of block. See a picture below:
When inserting a block, Elipse displays a configuration windows like this:
Where is write “Tamanho do bloco: 10”, you must choose the number of elements of block and them the block is inserted correctly.
Regards,
Felipe Valentini Oliveira
